Transmission converter control solenoid
I have a 2005 Crossfire limited cpe. I purchased a few months ago that had many issues that I corrected, and was running fine until last week.
I drove it for about five miles and it shifted fine until I came to a red light.
I pulled out from the red light and heard the transmission whine some while it shifted through the speeds to fifth speed. When I stopped at the next red light and tried to pull out again the transmission would not move or shift. I moved over and turned off the engine. I let it sit for a few minutes then started it back up again, and put it in gear and it pulled out okay. I didn't go very far when I felt it slip back into a nuetral position with no drive pressure.
I moved off the main road, and turned it off again, and called a towing service and had it towed home.
When the towing service dropped it off I started it back up and mived it in reverse and drive again.
I checked the transmission oil level and it was up past the full mark but the oil was clean. Before this problem occured the oil was at the proper full level.
It almost seems like it is a bad transmission converter solenoid. Also, there are no transmission codes showing up with my code reader. Has any one on the forum had this problem, and can offer some help.
crossfire5
