DO NOT USE R12. The service manual ONLY mentions R134 and has this paragraph :
CAUTION: Liquid refrigerant is corrosive to metal surfaces. Follow the operating instructions supplied with
the service equipment being used.
Never add R-12 to a refrigerant system designed to use R-134a. Damage to the system will result.
R-12 refrigerant oil must not be mixed with R-134a refrigerant oil. They are not compatible.
Do not use R-12 equipment or parts on the R-134a system. Damage to the system will result.
Do not overcharge the refrigerant system. This will cause excessive compressor head pressure and can
cause noise and system failure.
