Thread: Front End Work
Old May 30, 2015 | 10:48 PM
1sweetride's Avatar
1sweetride
Default Re: Front End Work
I took the wheels off to replace the brake fluid and noticed both front tires are worn on the inside edge. Believe the condition is called "scalloped or feathering". I could not find any items that were worn and since both tires were affected believe it is an alignment issue. According to shop manual, lower control arm mounting bolts have to be replaced with adjuster bolts as alignment is factory set.
Has anyone experience this with there front end alignment?
I am thinking of replacing the bolts myself, then having alignment done to reduce cost at any shop instead of dealer.
