Old May 31, 2015 | 04:27 PM
onehundred80
Default Re: S/C Pulley Shims
Originally Posted by Thornh
I am getting a constant .0025 all the way around with engine at operating temp. Am I correct in measuring this in thousandths of an inch or should I be looking at the metric scale?
I doubt you can measure that gap within .0005", so I'm thinking you have .025" gap, which is a bit high I'd say. But .0025, if it is that, is too close.
I think you have probably made a typo on the dimension, .025 is less that 1/32" by .007".
You can measure it in any system you want, let's stick to thousandths for the US market though.
If I recall correctly the OEM should have .012" to .016" (.30 to .40 mm) gap.
After market ones should be as the maker says I guess.
