Thread: Help!
Old Jun 19, 2006 | 02:29 PM
intenseblu's Avatar
intenseblu
Default Re: Help!
Cyril, your tire up front is a 235/35/19 (25.5 diameter) and mine is a 235/40/18 (24.4 diameter) ... you definitely have the same issue as i did...
time to bust out the cut off wheel and grinder and buy a new set of front tires... there is about one inch of extra bolt length you can remove, however if you ever have to reinstall the upper arm bolt you'll need a C clamp to squeeze it down to do so...
