The SLK grooves are not that deep. I measure .090". Shop plans to make a tool to duplicate the stock groove shape and I left him a belt with the fact it needs to sit flat against the pulley after the machining is complete. the grooves measured at the largest diameter after cutting should not be less than 68mm if cut at .090", 2.25mm's.
