Cyril, those tires are already ruined so you will need a new set, this gives us the option to get a set that will not have the same problem 225/35/19 will be 25.2 inches in diameter which will be .1 inch taller than stock but no wider... judging from the wear marks this should be enough to remedy the situation...
also, for good measure:
...the bolt i colored in red, i took about half a inch off of mine, but you can bring more off of it since your car is lower ... only take off what you need as the ball joint is impossible to install if without the extra bolt length if you ever take the suspension apart ...
