Re: How to Repair Relay Control Module (RCM) - (Mystery no Start)
ultrajim49
I should be able to do this...LOL! I just picked up a soldering & solder iron at Walmart on my lunch. Will drive to wife's work straight from work to get the most sunlight. I do have a question... after I open up box and unplug all wires... is RCM board just sitting in there lose or is it connected to something else I need to disconnect? I'm assuming one important point is to not have solder melt onto the connection next to it. If by some slim chance this doesn't resolve my car not starting problem....where do you suggest I look next. Thanks in advance for all the info on this site and any future suggestions and help.
Depends on your no start symptoms. It may not be the RCM.
The RCM removes very easy and is just clipped in place.
If you have never soldered before google it looking for video results. Use only rosin core solder. Heat the board till the solder melts on the board while feeding new solder to the board not the iron.
