Old Jun 18, 2015 | 08:37 AM
amx1397
Default Re: testing rear gears and pulleys
Originally Posted by ImportLabSRT
Sounds expensive.... but will be the answer to all the pinion failures with the stock style units.
not as much as you would think.,, I have broken 4 diffs. and one axle. their cost with labor to change everything everytime , is about equal , with the v8 only I have have only one diff and one axle that i have failed.
to do the ford 9" of course the first one cost the most, I tested the 327 set up, and now a few people have it ,, I tested the 346 and it worked some may want just that. And now it is time for a ford 9" , thanks Les ,someone has to do it. the 346 at this time is a open rear ,we have not found a posi for it. that is why i want to go with ford 9"
updated test on post #2 jim
