Old Jun 23, 2015 | 02:06 PM
Keepmeinmind13's Avatar
Keepmeinmind13
Default ok maybe someone out there can help...
So i bought the car about a month ago…it was driven about 200 miles home and then another 100 miles on 2 different occasions. Just last Friday i started it up and took it for a 25 mile run. everything was working perfectly. I parked it and went to start it monday but now it won't start. The battery is brand new. When you turn the key you can hear the starter click a few times and then nothing. all the electric comes on and works AC blows cold…the fan for the motor seems to turn on and run really hard. The engine doesn't seem to want to even try to turn over. I tried pumping the gas pedal nothing there. i thought maybe the ignition was the problem but the key does turn and i can move the steering wheel when the key is turned. Battery is brand new and i know nothing was left on in the car to drain it. You can hear the starter click so i don't think that is the issue…it has a full tank of gas…i tried 2 different keys in case it was a security issue with the key….any ideas?
Thanks
