The clicking you hear is most likely the starter solenoid. The way the circuitry works, when you trun the key to 'start', it energizes the starter solenoid coil. The solenoid has heavy duty contacts sufficient to carry the heavy current draw of the starter motor under load via their attachment to the battery. When you hear the clicking when you turn the key, you hear the solenoid pulling in it's contacts which supply current to power the starter motor. (the starter us usually grounded via its connection to the motor) If the starter motor does not respond and crank the engine via its gear mesh in the flywheel, then it seems therein lies your problem. Many things can be the problem: burned solenoid contacts; loose or coroded or dirty calbe from the battery to the solenoid contact. Weak starter motor etc.
Since modern starters are integrated with their solenoid It may be and often is that replacement of the starter/solenoid unit corrects the problem, since so doing usually exposes any cabling issues which may exist.
Now this is just my observation, to give you some perspective into your issue. It is also rudimentary, and not necessarily all that is involved in your issue with the crossfire. It may give you perspective when you discuss this issue with a professiional.
Rusty
Keepmeinmind13
So i bought the car about a month ago…it was driven about 200 miles home and then another 100 miles on 2 different occasions. Just last Friday i started it up and took it for a 25 mile run. everything was working perfectly. I parked it and went to start it monday but now it won't start. The battery is brand new. When you turn the key you can hear the starter click a few times and then nothing. all the electric comes on and works AC blows cold…the fan for the motor seems to turn on and run really hard. The engine doesn't seem to want to even try to turn over. I tried pumping the gas pedal nothing there. i thought maybe the ignition was the problem but the key does turn and i can move the steering wheel when the key is turned. Battery is brand new and i know nothing was left on in the car to drain it. You can hear the starter click so i don't think that is the issue…it has a full tank of gas…i tried 2 different keys in case it was a security issue with the key….any ideas?
Thanks
