Re: Dash light!...?
Hi Frogwash, The light indicates that the fluid in your radiator is low. Check the overflow tank for the correct level. Park car on level ground & check when fluid is cold. There is probably a sensor in the overflow tank that may need to be cleaned or the electrical connector is loose. You need to get an owners manual, available at the dealers if you want a new one or ebay for used. Also, you need to download the service manual available on the forum. This should be an easy fix.
