Old Jun 25, 2015 | 02:49 PM
  #897 (permalink)
ala_xfire
Default Re: How to Repair Relay Control Module (RCM) - (Mystery no Start)
Originally Posted by ultrajim49
On this RCM fix...do I want to completely melt away the old solder or just add new solder on top of the old? Do I heat the pins on the board to draw in new solder or just heat the solder and let it drip onto the contacts? Is resin core solder the same as rosin core solder? Sorry for all these questions...I' m just ' detail' type of person. Thanks in advance for any info on this.
Use a solder sucker or solder wick to remove all the old solder.
Proper soldering technique is to heat both components equally to a point where they will melt the solder applied to them. You are looking for a nice shiny finish when done.
Do NOT "drip" solder onto them.
Yes, resin and rosin are the same, do NOT use acid core solder ( meant for plumbing purposes )
The joints require quite a bit of heat, a soldering GUN is better that a soldering PENCIL here.
http://d2pbmlo3fglvvr.cloudfront.net...5VZZ2_AS01.JPG
