Re: Radiator Cooling fan not working
Power Train Control Module.
It's in the box by the battery along with the RCM and BCM ( Relay Control Module & Body Control Module )
It is the board in the center.
battery -> BCM -> PTCM -> RCM
disconnect the battery ground lead, then disconnect and reconnect all the PTCM connectors, reconnect battery and see if this helps.
