Old Jun 29, 2015 | 09:03 PM
jd007's Avatar
jd007
Default Re: Cabin Air Filter
Take the cowl off and look for more leaves there as they can block the drains under the windshield and flood the car inside.
If you do not want to take the cowl off you can use a flashlight and peer under the rubber toothed barriers at each end of the cowl.
I had the same problem leaves in cabin filter, change to new carbon cabin filter.going to remove the wiper blades in the plastic cover see if there's any more leaves and debris.been raining a lot here in Jersey so yeah I'm getting water leaking in...
