Re: Sprint Booster install...
Laugh if you want but I've never been more frustrated in my $%$*# life! First I tried to take the peddle assembly out but that %&$%# washer would not come out no matter what I did (magnet, wiggling and pry method etc.) so I then resorted to the "super glue method" by applying super glue around the rim of the socket and hoping the washer would stick. NOPE! Instead the glue leaked and now the washer is literally welded via superglue to the bottom of the plastic housing and stuck at the bottom permanently!
Method #2: Removed the two Philips screws and the plastic console but can't for the life of me disconnect the damn electrical connector. My fingers are literally bleeding trying to squeeze the two ends and pulling out simultaneously. There is no room! Even had my buddy climb into the passenger side and use a long straight edge screw driver to pry up while I was squeezing the two ends together. Nothing! I don't $&#@&#@ get it!
Anyone want to buy a SprintBooster (Automatic Transmission 3-mode version (off, normal, or race mode)? I'll sell it for $200.
