Re: Coilovers...
Ok, kw is spendy and bc is dc lol but don't worry. I have the answer for you. First. I lowered my car with eibach pro kit springs. During my search for coilovers, I did all the research and found that k sport makes a kit that sits the Crossfire but supposedly only the srt6. The kit cost about $900 depending where you order from. now here's the thing. The rear fit perfectly. The front needed a little creative thinking but will work. You see, nobody makes a true "coilover" kit for the Crossfire. What you get is an adjustable shock and an adjustable spring and they fit in the factory mounting brackets. Problem is, the front. The adjustable spring perch doesn't fit on the lower control arm so you need to use a different spring since the one that comes with the kit is really short. If you order the k sport kit, install the rear first so you understand what you need to do with the front. Since I already had shorter lowering springs I just used the eibach front springs and added the adjustable shocks. The shocks are how you adjust the cars ride height and the springs adjust for rebound so that's what's important. But the k sport kit is the only one I found that will for sure work on the Crossfire. Here is a pic of my car with the k sport kit installed. Hit me back if you have any other questions. Hope this helps.
