Thread: Colorado SRT-6
Old Jul 5, 2015 | 12:49 PM
leaddog2015's Avatar
leaddog2015
Default Re: Colorado SRT-6
Originally Posted by velociabstract
Beautiful! Most that choose a supercharger pulley over the crank pulley is for ease of installation and removal. Literally 15 minutes once you have done it a few times and have the tools you need. Remove fan, remove belt, remove pulley and reverse. The crank pulley requires lots of torque and a special tool to keep the engine from turning while the new new pulley is torqued down. A lift is highly recommended and 2 people. A 3/4" torque wrench that reads over 150 ft lbs and a breaker bar. The 178 crank pulley makes more boost/power than a 65mm supercharger pulley. Can't speak about the other pulleys as I've only had the 65 and 178 on my car.
Les
Thanks velociabstract for the info. My guess is that the crank pulley would also "overdrive" the other accessories. Wouldn't that wear them out?
