Thread: 158 Mph
Old Jun 21, 2006 | 04:33 PM
feets's Avatar
feets
Default Re: 158 Mph
Originally Posted by scot1981
you can have all the horse power in the world and it is shaped like a brick it will not beable to reach top speed like that of a smooth wedge shape one with 1/2 the power. also if you ever watch some cars that drag race that have 500-700 hp that only reach speeds of of like 130 or so, if they had that power in a more aero dynamic car with taller gearing it could go nearly twice as fast. i was mearly over stating that power namely is not as important and gearing and aero dymanics. just look at the c5 corvette and the c5 z06, z06 had more power with only a slightly higher top speed, 5-10 mph.
There are two kinds of top speed. Aerodynamic induced and RPM induced. If your car doesn't have the wheaties to push the air out of the way at a 6,000 rpm redline in top gear, you're simply not going to hit that rpm. Therefore, your speed is limited by aerodynamic drag. If you add power and are able to hit the target RPM, you're going to have a higher top speed that will become RPM limited. In this scenario you run out of gear, not motor.
The non-SRT cars would probably be aerodynamically limited if the artificial limiter wasn't there.
There's not much RPM left after the speed limiter kicks in so it'd probably be rpm limited.
