Re: Bas/esp
Blackout317
I believe so, on my other limited when the light would come on the reset with the turning the wheel all the way to the left and then all the way to the right would clear the light. This time it does not clear. I could be mistaken tho.
I'd go here and do the tests, not sure if you have the equipment required.
2004 Service Manual, 5 - 124 BRAKES - ABS ELECTRICAL DIAGNOSTICS, STEERING ANGLE SENSOR CIRCUIT.
Check fuse #14 (?) under the hood as well.
