Thread: Oil Change
Old Jun 21, 2006 | 05:31 PM
RickB's Avatar
RickB
Default Re: Oil Change
Originally Posted by Idaho
They are about $50 from Overton's, a lot cheaper, quicker and easier then the $300 aluminum low profile ramps I was using. Now I only use the ramps to replace the fog light when they get broke.
I bought an electric oil change pump at Bass Pro for $20. The unit empties the engine in less than 10 minutes, but will only work when the oil is hot, like I'd ever change it when cold. I found that a used cat litter bottle is more than adequately large to hold the output, as the pump just has a hose to feed to your own disposal container. At least Autozone takes the litter bottle with oil for recycling.
