Old Jul 9, 2015 | 01:20 AM
4drturbo's Avatar
4drturbo
Default Re: Oil Catch Can Q's
B is the correct way for the venturi port
Thank you
That is correct, I initially answered this on a i Pad on which the pictures A and B showed no real detail, hence the description.
Gotcha, thanks.. I was a bit confused with that post haha.
Originally Posted by HOT FIYA
I still need to install my catch can. And my boost gauge. And my taillight overlays......
lol
No need for a boost gauge, just get a UltraGauge. You can read boost from that.
Update. Finished up NeedsWings catch can install. Here is some more pictures and info related to the install. Sorry for the lack of quality, used cell phone. I take my time on any first install
I just zip-tied on the port on the bottom of the TB. Used the provided clamp on the drivers side of the T. (Not pictured) I attached all this before installing the TB on the car. I tried to torque the TB bolts down to 15ft lbs, but both my torque wrenches must be wrong because that was REALLY tight at around 10-12 ft lbs. Didn't want the bolt to break. I do notice the TB has a tad bit of play if you grab it and move it around. I am guessing its due to that spacer. Not sure what the purpose of that bracket on the lower portion of the TB is for? I don't see any use for it, its awfully close to that sensor that goes in the charge pipe T, directly below the TB.
Routed the throttle body line through that little gap like factory, then up near firewall.
Shows how catch can is mounted with the bolt, washers and nut.
Where it goes into the body.
Passenger side on how I have the line routed
All routed. Bad flash makes everything look filthy haha
Pretty intake back on
