Old Jul 9, 2015 | 03:48 AM
shawnwatson9493's Avatar
shawnwatson9493
Default Front eccentric caster/camber install
Hey guys,
I installed the eccentric bolts on the front passenger side, getting ready to do the driver's. On both the bolts the only way I could get them installed was to have the flat side of both washers pointing in opposite directions. So when looking at the head of the bolt it would be like D, while the nut side would have the flat spot pointing to the right. I am hoping that is just a 0* position and the alignment shop will adjust it as needed. Any thought s?
Also, if anyone has installed the kyb shocks, did any one notice that the rubber grommet on the top doesn't compress as far as the stock shock? Is that OK? Or did I do something wrong?
Thanks a lot for the help.
