Old Jul 9, 2015 | 02:26 PM
Kodebuster's Avatar
Kodebuster
Default (*) Run Flat Tires ~ Viable Replacement Option...???
My brother just leased a BMW and it comes with No Spare tire, but has Run Flat Tires as standard equipment.
Dealer told him you can run with a flat for up to 150 miles (at a reduced speed of 50 mph).
I was not familiar with these tires, but it sounded like a viable replacement option on my Crossfire.
Was wondering if any xFire owners run with any of these, or any comments...
I found the following info on the Edmunds website:
[Pros:
  • You can drive on a flat tire: The primary benefit of a run-flat tire is that it allows you to keep driving about 100 miles after all the air has gone. This means that a person doesn't have to get out of the car in the cold, or the rain, or onto a busy highway or on the street in a sketchy part of town. Drivers will usually have to reduce speed to about 50 mph to get the maximum range. The owner's manual will have exact figures for each tire/vehicle application.
  • Better stability after a blowout: Because this tire can support the vehicle without air, a sudden deflation results in less weight transfer and tread destabilization. Steering and handling will remain near normal.
  • Lower vehicle weight: With the spare and tire repair tools eliminated, vehicle weight should theoretically go down. But it's not as much as you might expect, since run-flat tires weigh more than regular tires, due to the added sidewall reinforcement.
Cons:
  • No spare: Vehicles equipped with run-flat tires carry no spare, which means they don't have the jack or tools either. In fact, eliminating the spare and reallocating that space to some other purpose (styling, third-row seat, interior room, etc.) is a big reason why carmakers offer run-flats.
  • Reduced tread wear: A recent study by J.D. Power found that people were replacing their run-flat tires an average of 6,000 miles sooner than owners using standard tires. Opinions differ on why this is, but one theory is that tiremakers put a soft tread compound on a run-flat tire to counter the hard ride. A side effect of the softer compound is a shorter tread life.
  • Blowouts are still possible: If a driver fails to heed or notice the run-flat warning and drives beyond the zero-pressure range or above the speed limitation, the tire can begin to disintegrate, with the same destabilizing effects. Additionally, if the puncture occurred on the sidewall or if the tire hits a large object, the driver would have to call a tow truck. The J.D. Power study found that "customers with vehicles equipped with run-flat tires are nearly twice as likely as those with vehicles equipped with standard tires to have to replace a tire due to a flat or blowout."
  • Hard to tell if it is low on air: A side effect of the stiffer construction is that the sidewalls do not bulge if the air pressure is low. This means that it is critical to have a tire-pressure monitoring system and check your tire pressure frequently.
  • Harsher ride: The stiff sidewalls that make a run-flat work also result in a harder ride. If the vehicle came with run-flat tires from the factory, the automaker usually tunes the suspension to offset the harsher ride.
  • Cost: Run-flat tires are more expensive to replace. A 205/55R16 run-flat tire at a local shop in Santa Monica, California, costs $239. The standard tire equivalent costs about $174, a $65 difference per tire. Also, many run-flat tires cannot be repaired and often need to be replaced in pairs.
  • Less on-shelf availability: Because run-flats aren't a big-selling tire, drivers shouldn't expect to roll into just any tire store and buy one. It may be easier to do so in larger cities, but if you're a run-flat user on a road trip and get a flat near a small town, you'll probably have to make a detour to find a suitable tire dealer. Or worse, you may have to stay there overnight, waiting for the tire to be shipped.]
