Re: Possible solution to LED hyperflash without the need of resistors?
Yur gunna make me do the math? I wanted you to do the math...
Seriously, no matter. Watts is power current is amps. We save all the amps on LED's then use it on aftermarket subs.
The "fix" to the turn signal issue seems way deeper than I need to go. I like simple and simple would be use resister LED's for the turns and the rest as you say. Whalla, simple.
