Old Jul 14, 2015 | 01:08 PM
Buttercup Girl's Avatar
Buttercup Girl
Default Re: Convertible Top Switch fell into console
I have the trim partially lifted off. I am afraid to try to get the rest off for fear of breaking. The front part of the clip is broken on the trim and if I get it off I would (hopefully) get the broken piece off. I also thought of measuring the switch and have a little bracket fabricated. I would epoxy that on (it was just a thought) so afraid of breaking the trim 😩
Originally Posted by RED DOG
They do become available on E-Bay occasionally but your search is more difficult because you need the more rare trim piece for a roadster (that has the hole in it for the top switch). Here is a current listing for the complete center console.
Chrysler Crossfire Dark Slate Gray Center Console | eBay
Here's another one (I think) . . .
05 06 07 08 Crossfire Console Front Floor Conv MT 366457 | eBay
So you've taken the console out and found that one end of the clip has broken off, right? Do you have the broken piece? If so you can get some epoxy glue and glue the broken clip piece back in place. Then after everything set up thoroughly and you pop the top switch back in place, you can put a cable tie / wire tie around the entire clip in section to hold it securely. I've had to put the cable ties on my power window switches to hold them securely in place.
