Old Jul 14, 2015 | 11:13 PM
KDW4Him's Avatar
KDW4Him
Default Now that you own a crossfire, a starters guide to ownership...
Now that you own a crossfire, a starters guide to ownership... Because of some of the posts I have seen over the past four years here are some pointers to make ownership a little less frustrating when an issue arises. As with any mechanical device it will need attention now and then and the same goes for our Crossfires.
1) If you have only one key, buy a second one…right now. Seriously right now, don’t leave your car stranded somewhere just get it on order. http://www.needswings.com EDIT; SEVERAL OTHER SOURCES ARE NOW AVAILABLE. CHECK THE TREAD ON THE TOPIC AND THE MERCEDES SWAP SHOP..... EDIT; AND TEST BOTH KEYS IN THE DOOR TO MAKE SURE THE MECHANICS OF THE DOOR LOCK ARE WORKING. We have had reports of batteries going dead and the key not turning the lock release mechanics inside the door.
2) Re-solder the solder joints in your relay control module. Even if they “look OK", just re-solder them. Clean the relay contacts too. https://www.crossfireforum.org/forum...-no-start.html
3) If you suspect a weak/old battery get it replaced. Period. These cars act weird even with old batteries that test "good." Some say spoiler deployment when the key is turned on or the car is cranking is the built in early battery failure warning system. Just replace it.
4) If you have not done the “sticky key mod” do that mod… soon. https://www.crossfireforum.org/forum...ru-2006-a.html
5) Replace the crank position sensor with the real Bosch part and put the working one in the glove box with the tools to replace it. https://www.crossfireforum.org/forum...or-photos.html
6) If you have a problem don’t take it to a dealer or start throwing parts at it until you have read the entire archives of the forum. There are a bunch of tech savvy people on here that can save you a ton of money but they can only help BEFORE you act. If you post a question here please be as detailed as possible. These cars have overlapping symptoms for a no start condition. Leaving out details will complicate the over the internet diagnosis and prescription.
7) If you "mod" the car document what you did for both your mechanic and the next owner. I have seen too many posts where an owner has to wade through a mod of some sort to find or diagnose a problem.
8) Aftermarket accessories; Crossfire members can help you with the car but we may not know the accessory. (Alarms, Remote start, HIDS, etc.) You may not have a car issue, you may have an add on issue.
9) Research the issue; If you go to the trouble shooting section on the forum to look up a particular issue please read the entire thread. If you read the procedure and get stuck at a specific point in the repair odds are someone else did too and posted about it asking the how to get past the..... whatever questions. You will see several follow-up posts about the original fix that will greatly help with the fix you are trying to do and it will give you a feel for the difficulty of the repair. If you post a new thread or problem please, after the repair follow-up your post with exactly what was done to fix it. This will only help other owners.
10) And most importantly enjoy the car, enjoy the "cult" following and have fun meeting up with other owners of the car. There is truly no better group of car owners out there than Crossfire owners! WORLDWIDE!
