Re: Allow me to introduce My self
I had read on here yesterday about the battery causing problems but I didn't expect this. I do have a Volt Ohm meter.
To answer you questions. Yes the windows go down.
Yes the I have checked the divider switch and the divider snaps in like it should.
No I'm not sure what the unlatched switch is and I listened to see if I could hear the trunk latch switch and did hear something but not sure if what I heard was the trunk latch switch. I did check those fuses last fall and they checked out good with my volt ohm meter.
lock switch on the dash does lock the doors.
I went back out there a few minutes ago and it started right up but the abs light esp and battery lights were still on. On the bright side the radio also started working.
