Thread: Rear Bow Latch
Old Jul 17, 2015 | 10:49 AM
mike28117's Avatar
mike28117
Default Rear Bow Latch
Top Hydraulics to the rescue again!!
I recently had the occasion to have some work done on the hydraulic cylinders that retract the roof. I initially worked with Klaus with Top Hydraulics to obtain resealed replacements for 3 out of the 5 cylinders. Once these were installed, I discovered that the microprocessor attached to the rear bow latch (that had not been replaced) created a ground fault. So, I called on TH and purchased a reconditioned rear bow latch. Now that it is installed, problem solved. I would like to call upon Klaus to discuss the technical details of this issue.
