pioneer4x4
Something isn't right with this image. I think that was part of my confusion.
Right Door has two (-) connections 1 & 8
Left Door has two (+) connections 2 & 3
Left Rear has two (+) connections 6 & 9
Right Rear has two (-) connections 7 & 10
Either the polarities are wrong, or the locations are wrong
or my understanding is wrong...
AH, from earlier in the thread I cut some of JesseJamessrt6's post, and this makes more sense even though he includes that image with the labels for the POWER AMPLIFIER A - BLACK 12 WAY connector.
JesseJamessrt6
I chose to cut the rear input pin wires # 3, 8, 8, 9,& 10 at the amp and ran new wire up to the new head unit converting them to a set of RCA's to plug into the pre-amp outputs for sub. Then from the factory wire loom plug behind the head unit I converted the front door speaker wires to RCAs as well to run into the new head unit's front pre-amp outputs.
speaker polarity and location according to pin # (thanks ppro);
AMP pin 6 - Right Door speaker input (-)
AMP pin 7 - Right Door speaker input (+)
AMP pin 10 - Right Sub input (+)
AMP pin 9 - Right Sub input (-)
AMP pin 1 - Left Door input (+)
AMP pin 2 - Left Door input (-)
AMP pin 8 - Left Sub input (+)
AMP pin 3 - Left Sub input (-)
duplicated diagram from previous posts showing which pin from the amplifier goes to which high level speaker input from head unit.
