ppro
To get to the e-brake connection you need to get the console out of the way. I just installed a switch on the console so I could flip the switch instead of take the console out and wire to the e-brake. I also had other reasons for doing that (enable features while car is moving).
I tested the red and yellow with a circuit tester to determine which was which and wired the correct ones to the connector. Yellow is Battery and Red is switched. IN the car they might be swapped.
My iPod is in the console - I hid the cable under it without removing the console - just slid it up under the edge and brought it up behind the back seat and down into the console through the cover.
My USB and 3.5mm stereo plug connections are stored in the little web catch-all on the transmission tunnel for guests or the occasional USB drive...
Ppro:
In the above thread you mentioned "
I just installed a switch on the console so I could flip the switch instead of take the console out and wire to the e-brake."
Just how was this "switch" wired? Wired from what to switch and then to what? Three pole? Two Pole?
Can you be a little more specific. I need to understand this. Please.
Regards,
Fildo Dog
