Old Jul 22, 2015 | 05:18 PM
onehundred80
Default Re: Where does this part go ????
Originally Posted by RED DOG
It goes behind the door where the wiring harness feeds over from the passenger compartment up over into the rear area of the car. If you raise the rear deck (like to put the top down) and look in there you'll see where the wiring harness comes through. That rubber piece is basically a sound insulator to keep noise from the rear compartment from coming into the passenger compartment. It doesn't just pop back into place and there is nothing really holding it in place. I had to put glue around the contact edges then insert it in place. Let me know if you don't understand and I'll get a photo and post it here for you.
RD has it nailed, Pulling the edge of the carpet away from the bulkhead behind the seats just below the window height you will see these neatly filling the hole for the harness going to the trunk. I have had both out and found it impossible to put them back neatly. They are somehow jammed in there now.
