Coolant Flush Question
Jul 26, 2015 | 08:58 AM
permalink
waldig
Feb 2008
4,508
34
VA
Re: Coolant Flush Question
Even an entirely safe way is to use a vacuum cleaners EXHAUST to blow the water thru. If you have a wet vac you can really void the system by sucking it out.
Me I dont care about the mixture as long as its about 50% or more to retard CORROSION. Its easy to do, get a antifreeze tester and check the mixture. IF your low, drain out some and add 100% antifreeze to bring up the precentage to your desired level. Save that amount drained as spare for refills. EZZY PEEZIE.
Enjoy W
DY
waldig
View Public Profile
Send a private message to waldig
Find all posts by waldig
