Re: Alignment and Make of Tire For 2005 Convertible
Yes, there is a toe adjustment for both front and rear, and both are adjustable from the factory, no additional parts required.
Isn't the front toe done by the tie rod adjustments ?
The caster however is not adjustable without additional parts, neither front or rear.
I just installed adjustable rear caster links I assembled from Speedway.com parts for a total of $79.90 for both sides.
I had laser alignment done yesterday, front toe was L : 0.04, R: 0.31 ( after R: 0.17 and L: 0.17 )
Rear toe before R: 0.22, L: 0.13 ( after R: 0.28 and L: 0.29 )
Rear camber was L:-2.3, R: -2.0 ( after L: -1.1, R: -1.1 )
My left front caster is still off by 0.3 degrees, but the tech said he didn't think that warrantied getting an adjustable caster set for the front.
NOTE: credit member scifi for the part info.
