Old Jul 29, 2015 | 06:06 PM
ZERACER
Default Top operation intermittent
My convertible top is driving me crazy. When I first unlatch from the windshield and push the button I get a beep and flashing light. I re-latch the top and go through the process again with the same result. After doing this four or more times it will finally come to life and go down. After driving it, the top goes up as normal. I know it is not the divider because it is in place and the top eventually goes down after the frustrations mentioned earlier. Could it be a bad contact in one of the switches? How many switches are there. Any ideas on which is the most likely culprit and how to test it? Do I need to just start replacing them one at a time? Does anyone know the part numbers and procedure for replacement?
Thanks for any suggestions and or information.
