Thread: Not starting
Old Aug 11, 2015 | 09:41 PM
Raicerx's Avatar
Raicerx
Default Re: Not starting
Fixed and fixed and fixed. Did i say it was fixed? Oh yeah. It is fixed. Took all of 30 minutes to remove solder and install the module and yes it works. You guys rock for posting the solution. Thank you. Btw my board looked fine no visual problems present. I did the repair anyway and it fixed the problem, so for those who think their board is fine, hit it with the solder anyway and give the pin a good long hit with the iron, make sure the pin is good and hot before you add solder it will seep in nicely forming a good bond.
