Old Aug 13, 2015 | 11:24 AM
ala_xfire
Default Re: 100,000 maintenance
No. NO! NO!
That code is usually a result of broken solder connections on the RCM board, 15 minutes and a 100 watt soldering iron and some ROSIN CORE solder and you should be fine.
Also, dragging your feet fixing this won't harm anything - that is just an emissions thing where you trade lower nitrous emissions for higher carbon emissions during warmup.
Mark, that's usually the air pump relay contacts, not the 3 solder joints.
