Old Aug 14, 2015 | 06:34 PM
ala_xfire
Default Re: Water in footwell
Yes. Remove the wiper arms and the plastic cowl cover. You will then see the water collection areas, one on the right and one in the center ( in US, may be reversed on RHD car ). There are rubber tubes connected to metal spigots on the bottom of the drain areas that can get clogged with debris. Gently rod them out with a wire of some kind. Do your BEST not to dislodge the rubber tubes from the spigots.
