Old Aug 16, 2015 | 10:02 AM
onehundred80
Default Re: Word to the wise !!!
After reading numerous threads about rust/corrosion in the rear wheel arches, I decided to have a look at mine. My roadster is always garage kept, seldom driven in the rain, never in any snow or salty roads.
I jacked it up in the driveway and removed the rear wheels.
Lo and behold, I found about a pound of black sandy dirt in each arch !
I flushed with hose, then used a fingernail type scrubber brush several times with flushing in between.
Now they are pristine !
If you plan on keeping your car, I advise you to have a look.
Also excellent opportunity to clean up all the suspension parts and fender wells, as well as the inside of the wheels.
( probably some WaxOil would be good too, but I didn't have any )
It is best to clean then you have been out in the rain as that softens up the muck held in there. Do not forget the fronts, a liner is there but that just hides the muck that has got behind it. There are about three spots where the build up can be felt.
Do not forget the bottoms of the doors either behind the top seal.
