Old Aug 18, 2015 | 10:18 AM
Mackel's Avatar
Mackel
Default Re: 3rd brake light partially lit
Originally Posted by Fla_Xfire_SRT
Is there a link or thread here that shows how to remove the trim on the coupe hatchback that will allow you to access the 3rd brake light? I am tempted to go to a body shop, but they would be guessing at it I am sure. ...Also I need instructions on how to get to the 3rd brake light on the Roadster as well, the left side is out. Thanks in advance....Peace
Raise the spoiler on the roadster trunk lid using the switch on the console. Open the trunk.
Remove the black plastic panel under the trunk lid by carefully prying out the clips holding it in place. These are plastic pop rivets that are removed by carefully prying up the center rivet. DON'T DAMAGE THEM AS YOU'LL REUSE THEM TO PUT THE THING BACK TOGETHER. Unplug the high-mounted brake light and unscrew the fasteners holding it in place. One of them, just to the right of the trunk lid latch mechanism is a little difficult to get to, but it can be done. Just be careful not to drop the screw once it comes out. You can then lift the entire brake light off the trunk lid by prying carefully. It is also held in place by some minor adhesive but will come off with gentle prying. Once you get it off you'll find that it is a sealed plastic unit with no obvious way of getting into it and still be able to get it back together. ALA_XFIRE's suggestion below to send it to the guy in Tennessee to repair would be my recommendation. Repair - about $100. New one (if you can find it) - $500.
