goodgenes79
Sweet2002, I do think Bigger Intake Manifolds would benefit anyone running stacked as it should lower your boost a bit and give you more adjustable A/F. Obviously once you max the charger then everything else is moot, so bigger intakes should help our little charger efficiently.
I think I read in another forum that manifolds will lower our torque a little but helping it breathe will give us some top end HP. My torque is enough to be almost unmanageable so giving me some up top is welcome. My exhaust helped open up the curve some too.
Perhaps. Please do a before and after with a dyno or the track. I need to look could at the return on the dollar. Right now I need more fuel for the stacked pulleys and a new TUNE! Obviously a tune, larger injectors coming, since it is lean up top. the SC is starting to get out of it's range after 15,000rpm. I go to around 15,700, about the same as the guys with the 62mm SC pulley. Good luck!
