Old Aug 21, 2015 | 12:41 PM
onehundred80
Default Re: Fob programming for door unlocking
[QUOTE=KDW4Him;845714]
Originally Posted by Red Paul
My car would not start, it was towed to an independent shop. The shop ordered 5099541-AA Module DO 08035031 from Chrysler. They also ordered 168-464-02-53 Transponder from Mercedes-Benz./QUOTE]
A SKREM, Power window module and the third? Transponder meaning the remote rx for the keys to lock/unlock?
If the SKREM is replaced it should have been able to "read" the existing keys or programmed to read the key RFID to start the car.
Not sure about a power window module on our cars because if I recall correctly the body control module does the windows so I am not sure how that relates to no start or no unlock/lock.
I am trying to get a complete picture of what the shops did.
I think you are confusing the issue, they replaced the SKREEM module (5099541-AA) and the coil transponder (168-464-02-53) around the ignition key hole.
No window module was mentioned that I saw, the SKREEM
is often called the Door Lock module.
