Old Aug 21, 2015 | 01:12 PM
ala_xfire
Default Re: Whats the best fuse to connect LEC Strip lights to to come stay on as running lig
You can find both switched and unswitched 12V at the rear of the under hood fuse box on studs you can connect a feed to.
( remove the top cover, then the inner cover, disconnect the negative battery terminal before fooling around in there )
I would use this and install an in-line fuse of your choice.
