My driver side subwoofer recently bit the bullet which brings me to this thread. I read through everything but I still had a few questions.
- What is the part # for the OEM subwoofer and where can I purchase one? I've searched Google a bit and haven't really found anything.
- Is the an aftermarket suvwoofer available at a lesser cost that is basically "plug & play"? I'm not interested in having to cut/modify anything to make it fit. I should also note that I have an aftermarket head unit (Clarion FZ501 media player). But i'm not looking for anything crazy - as clock to stock specs as possible.
Edit*
Found this while searching Google. Seems like it would be a practical replacement if you're not really looking to upgrade. It's 2 ohm and the magnet looks like it would fit w/o any modification. Still don't really know how it compares to the OEM woofer though. I searched high and low but couild never find what the specifications were for it.
http://www.parts-express.com/grs-6pr...m_campaign=pla
GRS 6PR-8 6-1/2" Poly Cone Rubber Surround Woofer
GRS 6PR-8 6-1/2" polypropylene cone woofers with butyl rubber surrounds are great replacement speakers, but also provide excellent performance in new projects.
Product Specifications
- Nominal Diameter6-1/2"<LI class=SpecLabelAltRow>Power Handling (RMS)60 Watts
- Power Handling (max)85 Watts<LI class=SpecLabelAltRow>Impedance8 ohms
- Frequency Response60 to 8,000 Hz<LI class=SpecLabelAltRow>Sensitivity85 dB 1W/1m
- Voice Coil Diameter1.5"
Thiele-Small Parameters
- Resonant Frequency (Fs)75 Hz<LI class=SpecLabelAltRow>DC Resistance (Re)7.55 ohms
- Voice Coil Inductance (Le)1.11 mH<LI class=SpecLabelAltRow>Mechanical Q (Qms)4.32
- Electromagnetic Q (Qes)1.34<LI class=SpecLabelAltRow>Total Q (Qts)1.02
- Compliance Equivalent Volume (Vas)0.24 ft.³<LI class=SpecLabelAltRow>Maximum Linear Excursion (Xmax)3 mm
Materials of Construction
- Cone MaterialPoly<LI class=SpecLabelAltRow>Surround MaterialRubber
- Magnet MaterialFerrite
Mounting Information
- Overall Outside Diameter6.5"<LI class=SpecLabelAltRow>Baffle Cutout Diameter5.625"
- Depth3.0625"<LI class=SpecLabelAltRow># Mounting Holes4
Optimum Cabinet Size (determined using BassBox 6 Pro High Fidelity suggestion)
- Sealed Volume0.29 ft.³<LI class=SpecLabelAltRow>Sealed F378 Hz
- Vented Volume1.48 ft.³<LI class=SpecLabelAltRow>Vented F343 Hz
- BrandGRS<LI class=SpecLabelAltRow>Model6PR-8
- Part Number292-426<LI class=SpecLabelAltRow>UPC844632088513
- Product CategoryWoofers<LI class=SpecLabelAltRow>Unit of MeasureEA
- Product Rating (52 Reviews)
- Weight2.85 lbs.
