Old Aug 21, 2015 | 09:58 PM
KDW4Him's Avatar
KDW4Him
Default Re: Fob programming for door unlocking
[QUOTE=onehundred80;845717]
Originally Posted by KDW4Him
I think you are confusing the issue, they replaced the SKREEM module (5099541-AA) and the coil transponder (168-464-02-53) around the ignition key hole.
No window module was mentioned that I saw, the SKREEM
is often called the Door Lock module.
Google found several power window modules with that number. The OP had 3 part numbers in it.
So the SKREM and antenna were replaced and only one key works. Too strange. Did the dealer give the owner back the correct keys?
