Old Aug 23, 2015 | 06:44 PM
KDW4Him's Avatar
KDW4Him
Default Re: Fob programming for door unlocking
Originally Posted by Mrmiata
Wild guess.. secret key code data corrupted during transfer???
The SKREEM retains in memory the ID numbers of any ignition key transponder that is programmed into it. For
added system security each SKREEM is programmed with a unique secret key code. This code is stored in memory,
sent over the CAN data bus to the PCM, and is encoded to the transponder of every ignition key that is programmed
into the SKREEM.
In the event that a SKREEM replacement is required, the secret key code can be transferred to the new SKREEM
from the PCM using the DRB IIIT scan tool and the ignition key system replacement programming procedure.
Proper completion of the ignition key system initialization will allow the existing ignition keys to be programmed into
the new SKREEM so that new keys will not be required. In the event that the original secret key code cannot be
recovered, SKREEM replacement will also require new ignition keys. The DRB IIIT scan tool will alert the technician
during the key reprogramming procedure if new ignition keys are required.
I don't think each key has it's own code for the RFID chip. I think both keys have the same code in the RFID chip otherwise we would have to specify which key when ordering a new one. That is why I cannot DX one key good and one key bad to start the car.
