Old Aug 26, 2015 | 08:14 AM
  #40 (permalink)
mobilefitt's Avatar
mobilefitt
Default Re: Vacuum leak, high LTFT, pcv hissing, HELP!!!
Originally Posted by Mrmiata
The one in charge of selling replacement parts!
Haven't dealt with it..
hopefully won't have to ..
but did read a couple threads on it..
Well at 155K, this is the first real problem I have had. If you would be so kind as to shoot up a link regarding that hose and it's replacement. I am afraid I am going to have to find a manifold with the hose intact. Or at least remove the manifold, and engineer something more permanent. Hopefully the threads include an easier fix than what I have in mind.
If i have to take off the manifold, I am going to have to look for a bigger one that fits now....
Anyone attempting to replace this hose should carefully inspect the entire hose. I believe my insertion of the hose was in much better shape than the part the turned to dust when I touched it. I could have cut the hose mid way and used a two sided brass nipple to connect a new piece of hose.
Problem solved. I assumed that there would be a nipple at the bottom of the manifold as there are on the top for 2 more suspect lines. NOPE! My hoses connected to these nipples looked ok but definitely were taking a beating from all the heat in the front of the manifold.
Hopefully this post will help save someone a few hours.
