Old Aug 27, 2015 | 10:32 PM
  #60 (permalink)
KDW4Him's Avatar
KDW4Him
Default Re: Fob programming for door unlocking
Originally Posted by pioneer4x4
Just remember to think of the key assembly as 3 totally separate devices which are only mechanically connected
1 - Mechanical metal key which manually allows things to turn.
2 - Keyless entry remote fob which uses batteries to transmit when you press the buttons.
3 - rfid chip which is charged from signal transmitted from ring near ignition switch, and then transmits a coded response.
Yes, three individual systems that somehow interact within the SKREEM. The internals to the SKREEM is where I am guessing.
One guess is if a FOB from your car cannot be synced to my car its because the SKREEM says your not one of mine due to RFID so it won't allow the sync. This would explain why the FOB needs to be IN the ignition to sync the locking.
Another guess is I could get 7 more keys from Needswings and only the first 6 would lock the car since my 2 already are synced for locking but all would start the car since the RFID is correct.
The best educated guess is one RFID per vin otherwise Needswings would need to know which FOB you are replacing.
We all may get this figured out...
