SRT 6 Engine parts, most all, used
Aug 28, 2015 | 10:01 AM
permalink
UrbanE
Dec 2014
1,255
301
CA
Re: SRT 6 Engine parts, most all, used
I'm posting this list of Parts on behalf of JimmieC. Please contact Jimmie for details.
Regards,
UrbanE
Chrysler SRT-6/Mercedes SLK 32 AMG 3.2 Parts
Good Quality Used 40K or less
Packed and stored in humidity controlled/climate controlledwarehouse since March 1, 2014
6 coil packs w/12 plug wires $480.00
Injection Nozzles (all 6) $350.00
Intake manifold Plenums, Pair $450.00
ERG Valves, Pair $ 95.00
Exhaust Manifolds, pair $175.00
Cylinder Heads (3.2SRT,AMG pair) $1,418.00
Camshafts, (SRT, AMG 2 each for boosted engine) $1,080.00
Camshaft gears, (SRT, AMG 2 each) $ 50.00
Rocker arm assemblies Complete (AMG Pair) $450.00
Valve/Cam cover assemblies (3.2SRT-6, pair) $176.00
Engine mounts (oil Filled Pair) $ 75.00
Cam Shaft Position Sensor $ 45.00
Crank Shaft Position Sensor $ 30.00
65mm Pulley for Supercharger is 11% overdrive $350.00
72mm Pulley (Stock) for Supercharger $200.00
Crankshaft, with gear, less bearings, FORGED,(3.2 AMG) $1,264.00
Duct, Air Inlet to throttle body with boots andclamps $ 75.00
Y pipe 1.6 AMG supercharger IntercoolerDischarge to intake plenums $200.00
Fuel Rail, AMG/SRT6 $ 75.00
Front Cover with oil filter Housing and Oilfilter cage, SLK32/SRT6 only $200.00
Oil Cooler SRT/AMG with S Shaped hose to waterfor cooling $214.00
Starter Ring Gear for 3.2 with AutomaticTransmission $ 30.00
Balance shaft with spur gear for oil pump chainw/bearing and weight $105.00
Timing and oil pump drive chains, 2 with guidetensioners $ 50.00
Upper oil Pan 3.2 Mercedes SRT6 $145.00
Lower oil pan 3.2 Mercedes SRT6 $ 50.00
Oil Level Sensor with internal upper pan wiring(3.2Mercedes, SRT6) $100.00
Chain, oil pump $ 12.00
Chain , timing $ 70.00
Chain Tensioner $ 48.00
Chain guide , right and left $ 24.00
Chain guide, upper $ 12.00
Aluminum tubing and rubber hose plumbing, airpump to ERG valves $100.00
Pulley, crankshaft, seven groove SRT6, 3.2 AMG,stock 155mm $134.00
UrbanE
View Public Profile
Send a private message to UrbanE
Find all posts by UrbanE
