Old Aug 29, 2015 | 01:48 PM
HOT FIYA's Avatar
HOT FIYA
Default Re: E Brake Cover/Boot?
Just got a reply back from them! I'll make some measurements asap and get back to them. Does anyone know if the rubber e-brakes surround is glued to the center console?
Hi Josh
We definitely would!
We can easily do that if you could help us with some dimensions. Firstly, we'd need to know if the stock rubber ebrake surround can be easily removed. Somebody told me it's glued into the center console, could you please double check that? If you take pictures while removing the center console you'll be half done with the install write-up by the way.
Once we establish that, it's only a matter of a few dimensions:
- the distance from the bottom edge of the surround to the ebrake lever fully raised (measured to the point on the ebrake handle where the top of the boot should be located, probably about 1" from it's end by the metal part of the lever I think)
- the distance from the top edge of the surround to the ebrake lever released (to the point on the handle where the top of the boot should be located, probably directly above the point where you measured the previous dimension)
- the circumference of the handle at this point.
- the size of the ebrake rubber surround opening (length and width)
If you have trouble deciphering this description please send me some pictures and I'll draw the dimensions on them for you to measure. Here's a picture that explains it: http://www.redlinegoods.com/ebrake_design.jpg
Have a great day!
Maciek (Mike)
RedlineGoods - Show Pride In Your Ride!
FB: RedlineGoods
